This was built for the goldrush hill climb in Queenstown originally at the moment it is getting a rear end change into something more reliable (Nissan Cefiro Cvs and axles ) did have Suzuki mini truck diff and axles and KLF quad cvs and well they just dont handle 120hp from the cbr
looks good dude
Pardon me, sir gangster! but it apears your pants are declining in elevation! |
Very nice. Why the pushrods for the shocks? Is that to get more travel out of short shocks or just to make them progressive?
not sure to be honest helps with both progressive and travel altough it hasnt got much travel anyway about 300mm from full extension to compression but with droop there is only 140mm before the frame hits the ground but there is a bit extra for pot holes and the such. it was set up for gravel although it gets around the paddocks pretty good.
hey man dont just be spamming your website, thats considered spam
If it shines, you will whine. Because Flat is where It's at! |
That looks really seriously MEAN!!! You build that? Tell us all about the kart, more pics, too!!! *drool*
The Manual- "Just the manufacturer's opinion of how to put this together."- Tim "The Tool Man" Taylor Put down the wrench, and come out with your hands up!- Me! Wrench, Wheel, Wreck, Repeat... |
There more photos in my photo bucket follow the link
![]() http://s157.photobucket.com/albums/t...0900R%20Buggy/ I will add more once im back at the shed with my camera and get it the mods being done completed. |
There a short video of it idleing on you tube i broke it just before i could some some decent footage .
Shocks set up like that reduce unsprung weight.
| The Following User Says Thank You to nosajwrx-7 For This Useful Post: | ||
Rustydog2010 (08-30-2010) | ||
#11
Please, this is a rather old thread, do not add comments that are otherwise unproductive to the thread. But on a lighter note, welcome to the forums. There's a great article in the Off Topic Fun section about new posters and basics of the forum. Click Here.
#12
What? but the post by Nosajwrx-7 is some what productive, as if you refer to post#3 it ask why use a rush rod system and was not answered, i didn't know and would have liked to know and Nosajwrx-7 answered it. And you wonder why people post once and then leave. And anyway if something is wrong isn't that moderators are for?
#13
Post #3 was also nearly 3 months old. If he truly wanted the answer, the poster would have bumped this thread asking for an answer to his question. Am I wrong? When is the last time we've heard from wingnut?
#14
@Model Engineer Cheers, that makes more sense lol |
#15
It increases unsprung weight as you now not only have half the shock unsprung (as before) but you also have the added unsprung weight of the pushrod, and bellcrank. Anything which moves with the wheel, and not the chassis, is unsprung weight so this includes the pushrod and bellcrank.
Andrew GS500F powered... |
#16
i didnt see this thead 3 months ago and i have seen this setup many times and i cant find info telling me why
thanks modelengineer
Buggy building Fast, reliable, cheap Pick two |
#17
The shocks in the picture are fully supported on the frame not the suspension. The push rods are half supported on the suspension and half on the frame, and push on the coilovers. They are not unsprung weight. But ohwell.
#18
gonna say, i agree with Nosa but the first paragraph of models makes sense
#19
Seriously, think about it for a bit. ANYTHING WHICH MOVES WITH THE SUSPENSION IS UNSPRUNG WEIGHT Does the shock move? Yes (half of it, anyway). Does the pushrod move? Yes. Does the bell crank move? Yes. The hub? The wishbones? Wheels and discs, etc? Yep, all unsprung weight. I should clarify that it IS possible to reduce unsprung weight this way if your shock is very heavy at one end. If a normal setup would mean the heavy end has to go on the swingarm, and a pushrod setup means the heavy end is mounted to the chassis, then that could reduce unsprung weight. I can give an example. If you have a pushrod system, with a shock that weighs 500kg, do you think it would cycle very well? The shock has a huge amount of mass which needs to be moved for the suspension to go up and down even though it's actuating through a pushrod. It's all unsprung weight. I think the reason most people get confused is that the actual weight force (due to gravity) of the shock is (mostly) supported by the frame. Perhaps a better term for unsprung weight is unsprung mass. Either way, they both mean the mass which has to be accelerated for the suspension to move. I hope this clears things up.
#20
I think that shocks, a arms and any part of the suspension that is attached to the frame are only partially classified as unsprung, not sure of the percentage. So maybe anything past the shock pushrod is mostly classified as sprung weight.
| Thread Tools | |
| Display Modes | |
