Old 04-09-2012, 04:18 AM
Nodroz's Avatar
Nodroz Nodroz is online now
Default Engine didn't start - fix.
Hello guys,
I had a little problem starting my engine last week. The day before he ran perfectly fine, but suddenly he stopped working. I decided to open the cilinder head and look inside for dust or other bad things.
Here are a few pictures. I also would like to know what caused such a big clumb of oil / gasoline.
Then, after some work, I completely cleaned the cilinder head.
After injecting fuel directly into the compression chamber, the engine started and ran fine.
The only question I have is how this can happen? (The oil/fuel onto the cilinder head.)
Regards,
Nodroz
Old 04-09-2012, 05:54 AM
klicky96 klicky96 is offline
2 Cycle? 4 Cycle?
Old 04-09-2012, 07:00 AM
the-cyborg the-cyborg is offline
Originally Posted by klicky96 View Post
2 Cycle? 4 Cycle?
Clearly a 4 stroke L-head note the intake and exhaust valves.
Old 04-09-2012, 12:21 PM
bighead's Avatar
bighead bighead is offline
I seen worse....
Attention Criminals!! This is a defense free crime zone. All law-abiding citizens have been disarmed for your convenience.
Old 04-09-2012, 12:28 PM
Nodroz's Avatar
Yeah, It's not that bad but I'd like to know how this could have happened?
Old 04-09-2012, 01:12 PM
kendelrk's Avatar
kendelrk kendelrk is offline
redneck engineer
rings
Great, now rebuild the engine.
Be a leader not a follower, but if your going to be a follower, follow the right leader
Old 04-09-2012, 03:48 PM
Worn piston rings
Scored cylinder wall
Worn valve guide seals (if equipped)
Like bighead said I've seen worse, but since you have it apart I'd hone and mic the cylinder install new appropriate rings, and re-lap the valves.
$20-$30 worth of parts and time will pit it back in action strong as ever.
Old 04-10-2012, 02:37 AM
Nodroz's Avatar
Originally Posted by the-cyborg View Post
Worn piston rings
Thanks for the information!
Do you think it's worth spending money on this old engine, or is it better to buy a new one.
Also, what will happen if I don't replace any parts? Will the engine die after some time?
Old 04-10-2012, 03:25 AM
Fabroman's Avatar
Fabroman Fabroman is online now
If you can get the parts cheap & easy enough, yes.
Eventually. First it will start blowing white smoke from the exhaust, then it will start losing compression &, therefore, power. all this will gradually get worse over time until you go nowhere in a cloud of smoke. How long will that take? Who knows? it could happen in a week, it might take a year; no way to tell...
Better to fix it now before you totally destroy your engine.
There's no better feeling than seeing something you made work
Nothing is impossible to fix if you have enough time, money & patience
Old 04-10-2012, 08:33 AM
Nodroz's Avatar
I've look up through the internet for symptons for a worn piston ring. I've read that blue smoke is a sympton, but I don't have any blue smoke.
Also, are you guys sure that, that dirt spot has been caused by worn piston rings or valves?
Thanks for the information Fabroman.
  #11
Old 04-10-2012, 09:56 AM
Fabroman's Avatar
Well, it's definitely oil & the only way oil gets into the combustion chamber is passed the rings or valves.
As bighead & the cyborg said, "I've seen worse". Your problem is in it's very early stages but it will get worse.
The only other possibilities are
1. you're using 2 stroke fuel which has oil in it or
2. you have a crack in the bore... but I doubt it.
Drop the piston down & have a reeeally good look at the bore, post some pics.
  #12
Old 04-10-2012, 11:34 PM
anderkart's Avatar
anderkart anderkart is offline
Take a look inside your air filter and see if its oil soaked. If it is, that residue is probably just oil that was drawn in from the breather hose connected to the air filter, and maybe some extra gasoline from repeatedly trying to start it with an oil-fouled spark plug.
Lots of karts have problems with the breather hose pumping oil into the air filter, this can be caused from something as simple as an over-filled oil level or even just hitting big bumps or turning a sharp corner.
One easy solution is to disconnect the breather hose from your air filter, plug the port in the filter, and then instal a fuel filter in the end of the breather hose so you wont draw any dirt into your engine.
______________________
_____________________________
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
