DIY Go Kart Forum
DIY Go Kart Forum (http://www.diygokarts.com/vb/index.php)
-   Engines & Clutches (http://www.diygokarts.com/vb/forumdisplay.php?f=18)
-   -   TC drive sprocket (http://www.diygokarts.com/vb/showthread.php?t=30119)
bocanegramusic 07-15-2015 01:24 AM
Itsid asked for the rear differentials gear ratio. It is 6 to 1.
itsid 07-15-2015 10:20 AM
well then, with that weight, wheelsize and final ratio..
16T TC sprocket might work.. (27.5 mph)..
it might fail in case youre differential is NOT 6:1 but say only 5.5:1
personally I'd dial in towards a 14T sprocket, just to have a safety margin for the diff uncertainty ;)
(~24mph.. but it will move with a 5.5 diff too ;))
since you have to have it machined to your specs, that's an expensive sprocket..
choose wisely!
bocanegramusic 07-15-2015 11:16 AM
I guarantee it's a 6 to 1. Marked the wheel before I turned it also. I think I'm going to go with the b type sprocket, shave it to match the c type, and get a few washers. What do you think?
landuse 07-15-2015 01:59 PM
Quote:
You will only know by trying:thumbsup:
itsid 07-15-2015 06:36 PM
single spacer.. not washers.. IF!
you did as I asked and counted 6 full rotations??? :eek:
ohoh....
bocanegramusic 07-15-2015 07:11 PM
Yes! 6 full rotations.....wait....are you being a meanie?😑
itsid 07-15-2015 07:44 PM
well see.. communication, I asked to tell us the number (not what you think is the ratio ;))
if you counted 6 full revolutions, since you've locked the other wheel, you have to multiply by two to know the ratio
so it's a 12:1 differential you have
see this for example (just I asked for ONE not ten rotations much easier to keep track that way ;))
www.youtube.com/watch?v=RNgjS5mHI0E
and with that 27.6:1 overall ratio your top speed shouldn't exceed 8.5 mph with a stock predator 212.
no way you reached 15 mph.... (or your engine ran 6400 rpm.. which I doubt)
Forgive me, but there is NO flying way we can give good advice with information as inconsistent as these...
well I can't at least.
bocanegramusic 07-15-2015 09:19 PM
...I will get my speed for you. From....my GPS phone. See what it calculates. And do a side by side compairison.
My stuff is,
23 tooth on the diff
9 tooth on my drive clutch
20" wheels
Comet 20 series TC
And of course....the 12 to 1 differential.
There must be something amiss....in going to order that 14 tooth sprocket.
bocanegramusic 07-15-2015 09:20 PM
One more question. Measuring a brake band is from one side to the other....correct?
Half-breeder 07-15-2015 09:23 PM
No... drum diamter is measured... looks like yours is a 4".
bocanegramusic 07-15-2015 09:36 PM
Oooh, the drum is 5.5 inches across. So 4?
bocanegramusic 07-15-2015 10:33 PM
Ok, I am only going 8 mph. Haha
bocanegramusic 07-15-2015 11:29 PM
So I am at a loss on what to do now. I bought a 14 tooth sprocket for the TC. I didn't think a 17 tooth would actually fit in the housing....so....any other ideas that don't cost an arm and a leg?
bocanegramusic 07-15-2015 11:40 PM
Ok so I checked measurment, a 41B17 5/8 bore, sprocket has been ordered. I cancelled the 14 tooth after we saw the dilemma. I really think this will change things. Anyone agree?
landuse 07-16-2015 01:30 AM
Quote:
A what tooth sprocket is that??
bocanegramusic 07-16-2015 02:03 AM
I guess sprockets are labeled in a code of some sort. 41 represents the chain size...the letter after represents the sprocket type. A B C or D....and the last number represents the number of teeth. Then the bore size or 5/8. So I ordered a 41B17 5/8 bore sprocket. And I'm hoping it will at the very least, come close to doubling the speed of 8 mph.
bocanegramusic 07-16-2015 08:49 AM
And I wasn't trying to be a smarty pants. Just sayin 😎
landuse 07-16-2015 09:07 AM
Quote:
Originally Posted by bocanegramusic (Post 373015)
And I wasn't trying to be a smarty pants. Just sayin ��
I didn't take it that way :D:D Don't worry about it
bocanegramusic 07-16-2015 01:35 PM
So what would be the speed at a 17 tooth on the TC?
OzFab 07-16-2015 07:42 PM
Since Landuse hasn't mentioned it, PLEASE STOP MAKING MULTIPLE CONSECUTIVE POSTS! There is an Edit button in the lower right corner of your posts, PLEASE USE IT!
If I was to merge all of your consecutive posts, this thread would be half the length it is...
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
