DIY Go Kart Forum
DIY Go Kart Forum (http://www.diygokarts.com/vb/index.php)
-   Go Kart Discussion (http://www.diygokarts.com/vb/forumdisplay.php?f=6)
-   -   got my tires (http://www.diygokarts.com/vb/showthread.php?t=21853)
momoe 04-29-2013 08:59 PM
got my tires
so finally i got my tires, they're burris slicks . 11x5x6 which is a perfect fit for the front and 11x7.10x6 for the rear
my rear rims are 7" wide, would that 0.10 make a difference at all for the worst or best ?
also, i kept watching how to mount it, ppl on youtube use that round hollow cylinder and pump the tires,,, what is that ? and do i need to do this ?! ?! or a simple mount and pump will do ?
thanks
OzFab 04-30-2013 10:29 AM
The "round hollow cylinder" you speak of is a bead seater; it holds the centre of the tyre in so the beads will sit firmly on the rim.
No, you don't need to use one, it just makes the job a bit easier. Simply remove the valve centre before inflating & you should be ok. Be careful not to damage the beads as you mount the new tyres.
The 0.1 difference in the width should make no differenc at all; think about it, that's 1/10th of an inch...
momoe 04-30-2013 09:00 PM
thanks, allready mounted and balanced in a tire shop, hope this helps other ppl
OzFab 05-01-2013 02:38 AM
Cheat :lolgoku:
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
