DIY Go Kart Forum
DIY Go Kart Forum (http://www.diygokarts.com/vb/index.php)
-   Engines & Clutches (http://www.diygokarts.com/vb/forumdisplay.php?f=18)
-   -   Hemi no start. (http://www.diygokarts.com/vb/showthread.php?t=34408)
Jfive 10-05-2016 02:30 PM
Hemi no start.
Installed a 22mm motorcycle carb, and can't get it to fire. Has custom intake. Header and governor removed. Never fired new with oem carb. Cam came out with cover but reinstalled with the piston at TDC and dots lined up. Now does it have waste spark or could that affect TDC if off a revolution.
Poboy kartman 10-05-2016 03:04 PM
Your pushrods are probably not under the rocker arms.
If you're not getting spark it may not have enough oil.
BirdFanatic 10-05-2016 03:14 PM
Is the pull cord trying to eat your arm ?
Jfive 10-05-2016 04:17 PM
Removed oil sensor filled with 16oz. Oil, but might be lifter. I had one that kept falling out. Had spark but didn't seam to get fuel. I'll get starter fluid at Wal-Mart tonight pull valve cover check that and retry.
---------- Post added at 05:17 PM ---------- Previous post was at 05:16 PM ----------
My arms tired from pulling it but just cause it would not start.
bob58o 10-05-2016 04:39 PM
Take off the valve cover, fix the pushrods, set the lash
---------- Post added at 05:39 PM ---------- Previous post was at 05:37 PM ----------
Or make it look stock and return it to Harbor Freight.
That is what I did, cause I didn't know to fix the pushrods.
chancer 10-05-2016 04:52 PM
Try not to Suck Bob!:lolgoku:
Jfive 10-06-2016 11:08 AM
Took the valve cover off, and both push rods were off the rocker arms. I'll assume that was it. Need to look up lash and I'll check it. Then later today I'll put it outside and retry to fire it up.
Poboy kartman 10-06-2016 11:21 AM
Quote:
That'll do it!!! You can double check...and someone correct me if I'm wrong...but on the newer Predators I believe they are 0.003" for both intake and exhaust.
aham2003 10-06-2016 11:38 AM
Quote:
That is what I set my last hemi build at and it ran great.
Poboy kartman 10-06-2016 11:45 AM
JIK....The lash needs to be set at TDC on the COMPRESSION stroke....TDC on the exhuast and it won't run.
Jfive 10-06-2016 02:49 PM
1 Attachment(s)
Probably has too much lash. I didn't check it yet but could see it with my eyes. Runs now and just need to have it mounted to get a video. Hit the throttle and I straight rips compared to oem carb on my lifan. Idle is low so I'll need to adjust it, but fired first pull. How I have it rigged to start.
Bbqjoe 10-06-2016 03:03 PM
Quote:
So, you're starting it with an angle grinder?
Jfive 10-06-2016 03:06 PM
Yes Pat pending.
Also runs on water from culigan.
Hellion 10-06-2016 06:59 PM
Quote:
Fooling around with the engine after the truth of the above statement was realized was your first mistake.
You did not purchase a functioning, viable product and the whole cash for goods transaction was null and void. You should have exchanged it at the store.
:oops:
chancer 10-06-2016 07:53 PM
Quote:
Did you read the thread? He messed up the lifters removing the Govna'
and he has already fixed his mistake.
But, hey thanks for posting, always good to hear from you:2guns:
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
