Shop Our Other Throttle Parts
Shop All Our Parts
Sheathed Throttle Cable
For Pedal Throttle or Mini Bike Throttle
For the mini bike motorcycle style throttle, you'll need the right cable with the right ends on it. This is correct cable with the barrel ends.
Also used for go kart pedal throttles.
Total cable length: 54 in. Cable sheathing length: 50 in.
110% Lowest Price Guaranteed!
For the mini bike throttle handles, you must have the right end hardware on the gas cable. Otherwise it won't all hook up.
This cable is also used for go kart throttles. If needed you can always cut the ends off and use your own terminal hardware to solve whatever situation you need to.
Brake cable will not work with the twist grip mini bike throttle.
