4) change to a "juggernaut" torque converter and gear for approx 28 mph at 3600 rpm.
- pros: will be able to rev the full range of the engine's ability, will accelerate very fast, belts will not burn up
- cons: cost, slightly lower "top speed" than buring up your clutches all the time, possible wheelies.
To be honest, I stopped using my juggernaut , the lack of adjustment and different springs , or any replacement parts sucks.
All you have to do is shim the regular 30 series clutch a little bit,
and it removes the 5500rpm ceiling
Just replace the original bronze spacer bushing, with a thicker steel ring. 0 cost. Wider the spacer, less top ratio, and keeps the belt from getting torn up, just like the juggernaut. The monster moto 212 bikes have a shim like this from the factory.
On a built high compression, 7500rpm motor,
works great, does not limit the top speed like a stock clutch,
and actually accelerates way faster than the juggernaut.
Cause if your clutch is not keeping your motor where it produces peak torque,
you are not getting the full pull.
Tuning the torque converter right can make a huge difference.
So what would the recommended gearing be? What should I change the back tire sprocket to? At this point top speed isn’t a priority. I just want good acceleration while keeping a decent top speed without to much wear on the torque converter
My 212cc monster moto is fine with the 50t in the back, I changed the drive sprocket from 10 down to 9, and 19in tires. regular 30 series, no worries, gets out the hole well and hauls. But 12 to 1 compression helps, you may still need more reduction.
